engraving, part 3, HELP
Highlighted
Newbie
hello proe cam users...
I´ve been able to create sequences (using engraving) that allow me to machine triangular ribs that gradually come out and then blend into the same surface they emerge from.
The only draw back is that the tool makes several cuts in the air, thus it is not efficient.
what other sequences can I use to machine this geometry??
thank you, best regards
al.
