i just saw through PTC University the program on hole tables. i can get the hole table to work on a flat sheet metal part, that works great,BUT when i go to create a bent featured sheet metal part the hole table only works on 1 surface and only those holes on that surface. i create my bent sheet metal on the fly then figure out where i want my holes (not extruded cuts). i have tried to move the hole features up the model tree to the 1st flat surface where it would be seen and still not successfull.
Rich Henderson
Design Drafter
here is what i was talking about, when this is unbent (suppress the flat pattern) the 5 holes along the long edge are the only holes that show up in the hole table. i have tried to move other features around in the model tree expexcting them to appear with out success. thank you for your help
Rich Henderson
Design Drafter
