how to perform publish geometry to make solid part instead of surface
Hi Guys,
I am interested to know how we can perform publish geometry option for creating a solid cross-section instead of the surface.
1 REPLY
Re: how to perform publish geometry to make solid part instead of surface
What is a solid cross section?
I don't understand why you want to use the Publish Geometry feature. That's just a way of grabbing the surfaces, edge chains, and datums that you would want to select in a Copy Geometry feature.
Dave Martin
dmartin@creowindchill.com
www.creowindchill.com
