<creo_loadpoint> is not able to modify
Highlighted
Visitor
Starting with Creo we want to use new enhancement process.
(I'm very intersting how will it work.)
Here is my issue regarding installation of Creo parametric.
It is not able to change Installation path for Creo 2 (and 1 as well). It is always .../Creo 2.0.
Existing start scripts has to be modifed because of space and dot. We have to use " " for path settings.
SPR 2123907 is closed:
“This is the design spec. The fact that this forced a path with spaces in it was raised during the design process”.
