not quite sure, if the software meets my design tasks
Highlighted
Not applicable
Which are the most common design tasks that can be covered by the software?
Highlighted
Re: not quite sure, if the software meets my design tasks
You can create * 3D solid models by extruding, turning, .. 2D geometry * Modify 3D models with mill, bore, punch, shell, ... * Create freeform models and geometry * Do assembly and part management (all in one mode) * Automatically ecognize features and modify, move, copy, delete them * Modify models with powerful commands like the ""move 3d"" .. * Derive 2D drawings from the 3D model with Annotation (see Application menu) * Do high resolution prints * Measure the model and show properties * Use the quickstart project to learn the tool
