problem using material removal after a local mill
Newbie
hello again proe pros...
I´m trying to create a material removal feature after a local mill sequence (which refers to a previous surface mill operation).
According to the guide I´m using I should be able to create the material removal feature without a problem.
However the comment line (lower left corner) gives me the following message: "ERROR: Cannot find mill volume or window for this NC sequence"
So far the following sequences and features make up the program:
1. Surface milling
2. Material removal
3. Local milling
4. Material removal (intended)
what can I do?? I need to update my stock piece.
thanks, regards
Al.
