render with "fuzz" on the camera lense
StephenW
23-Emerald II
Ok, so I'm doing some basic rendering. I'm by no means a good graphics guy. I don't even know what looks good. But this is odd, all the renders I do have odd dots on the output that looks like the camera lens has spots on it as if I need to clean it.
Here's a closeup. It's no zoomed up that much. All the little black dots are not supposed to be there. I thought it might be the transparency of one of the parts but it shows in areas that don't have transparency assigned.
[cid:image001.png@01CCE581.74AE1790]
It could be datums and the like not being hidden? This is an interesting
topic. I always get some grain/blur as well. I've never really figured out
why.
A clear case of processor/memory damage. Clearly your silicon components
have become smudged and small amounts of dust have made it into the CPU. I
recommend that you clean out the computer with compressed air and then
bathe it in alcohol for a few hours. Let it dry and turn it back on slowly.
always keep the computer level to make sure the bits don't shake out of the
drives.
On Tue, Feb 7, 2012 at 8:15 AM, Williams, Steve C <-<br/>> wrote:
> Ok, so I’m doing some basic rendering. I’m by no means a good graphics
> guy. I don’t even know what looks good. But this is odd, all the renders I
> it as if I need to clean it.****
> Here’s a closeup. It’s no zoomed up that much. All the little black dots
> of the parts but it shows in areas that don’t have transparency assigned.*
