surf mill question..
Newbie
Good morning guys.
I have a mold that I am trying to machine. The spacing in between each boss
is .034" I plan on using a .03125" flat end mill to machine the surface. I
am trying to create cut lines that will go over the boss instead of around
the boss. The tool would be cutting like a plunge mill but following the
contour of the boss. This is how the boss looks like. I have tried to create
cut-lines from edge it works but the end where it is rounded will start to
go around instead of up and over. I tried "cut line with projected" and I
can not get it right either. I am trying right now to use projected cuts to
see if I can get the path. Does anybody have any other suggestion?
Thanks.
Son Nguyen
CNC Programmer
108 W. 2nd Street
Assaria, KS 67416
785-667-7763 ext. 3477
Thanks Terry. I did not think of it I was making it harder than it needed to
be.
