surface definition
Highlighted
Newbie
surface definition
Hi users-
I have a round part. A 40 deg section
gets milled in between 2 ears to match the turned area
of the part. THe model diameter is 2.568. The part was
turned 2.573 to stay above 2.568 minimum diameter. I created
and trimmed the surface using a datum curve through a cross
section. I get a mismatch because of the different diameters.
is there an easy way to change the rad to match the part?
My only thought is to create a new part with a larger diameter
and redefine the cut. I also would like taper it up a little
to to where the turned area stops.
Rob Jeanjaquet
