Is it possible to simulate a weeble(roly poly) toy oscillating on a flat surface? I also want to calculate how long it will take to attain equilibrium under standard atmospheric conditions.(The red 'X' mark in the image below indicates the center of gravity). How do I constraint if this part is placed on a flat surface where gravity and friction are the only forces acting on them.
