Ability to add Selction Criteria Values to Heading of Query and Reports
0 Kudos
Is there a way to show the report selection  criteria such as the As Of Date ##/##/##  in the headin...
This question is Not Answered.(Mark as assumed answered)
Joe Summers   Bronze
Would like to know if there is a trick or function that you can use to show your query selection criteria on the report heading, like when you run a report as of a date it would be beneficial to see what information the report was run for. Instead of having to hand type the information in to the report each time you change the query selection criteria.
And the same ability to show this on your charts on Dash boards.
I need to show some selection but not all.
1 Comment
Hi Joe
While the report output page doesn't clear shows Title - "As of Date xx-xx-xx", it displays the selection criteria on which the report was run. Please see the following image of Document report run as of and the selection criteria displayed in the left side of the page.
I guess you are you looking for this information; if not could you please elaborate your requirement and send us the snapshot /image?
