Allow the 'Text Editor' profile dialog to be used when creating a new object from a profile menu
0 Kudos
The 'Text Editor' profile dialog can only be used to edit data for an existing object.
It would be helpful if it could be used when creating a new object from a profile menu option (i.e. within RunMenuUI), to allow a descriptions etc. to be entered before the object itself has been created, with a default value. This would be analogous to an InputBox (but allowing multi-line entry).
As a work around I have placed a Text Diagram in the profile itself, solely to use the Description field as the target for Text Editor.
However, this doesn't allow entry of a custom default value since the profile itself has to be Protected and changing the Description to set this default prior to invoking the Text Editor requires Write access.
