Change of the "Login Configuration" not possible after you used it once
Sippet from the User Guide "You cannot change a login configuration after you have used it to connect to a RE/
RM data source. Changing the credentials manually within the Connection will lead to a validation error."
Please add a possibility to change the Login Config for each user! We are using the "Requirements Connector" in a Team and each person of the teams needs to use his own login configuration!
1 Comment
Level 7
