Display parameter range in the info message when parameter is outside
Modeler allows to provide a range for parameter values on a variant.
If you enter in the decision set editor a value outside this range the user is just getting the message that the operation cannot be performed:
It would be great if modeler would show the defined range in the info message.
2 Comments
hi Ulrich,
I've added this requirement to our database (ART17-15869198) and we will consider for Modeler 8.5
regards,
Patrick
Status changed to: Under Consideration
