Fix Excel integration error that occurs with empty documents (SPR 5912986)
0 Kudos
Excel Integration Fails to synchronize with a document unless some document content already exists. This error can be recreated by synchronizing with a new document which has had no interaction since being created. It seems that this issue still hasn't been updated in the newer versions of Integrity. From what I know SPR's are no longer being tracked, so I am creating this product idea to suggest that this issue be fixed. It is annoying and unintuitive that this specific chain of actions leads to an error.
2 Comments
Level 8
SPRs actually are being tracked and that is the right way to follow-up on any issues. For any 'Enhancements' we recommend to use the ideas portal. I checked this SPR and is still open for us. I am closing this idea (As No Plans to implement - does not mean this will never be fixed, but I just want to close on this idea here) so that the issue gets tracked through SPR only.
Level 5
Status changed to: No Plans to Implement
Closing this idea as per the response provided earlier. Defects will continue to get tracked as SPRs.
Only new product enhancements are tracked on this portal.
