Improving the usability of the presentation template designer
At the moment presentation templates could be designed only with the designer inside the admin client. Quite simply: its a table designer without any flexibility in usage and in design. Here some examples of functionalites, which arent existing or strongly need some improvement:
  • possibility of nested tables
  • possibility of using one field more than one time in the same tab
  • possibility to change the visibilty of a whole tab
  • possibility to use embedded html-code
  • possibility to use embedded scripting (javascript or something like this)
  • possibility to import/export (parts of) presentation templates (without the need of getdb-/putdb-commands)
  • (easier) possibility to reuse (parts of) presentation templates
  • setting the visibilty of a cell
  • handling of graphics
  • changes should be shown in a history like for mostly all other objects
