Integrity Modeler providing multi selection in enumeration attributs
In PTC Integrity Modeler it is not possible to select more than one option in enumeraton attributes. This limitation must be removed as soon as possible.
Espacially for requirements useing multis selection attributes in the requirement management tool (i. e. IBM rational Doors) workaround are very constly.
affected Element:
Tag - Definition data type enumeration:
Example, tag definition used on stereotype requirement:
The proposal is to enable enumeration attributes for multi selection.
i. e. multi selection with check boxes, here enum 1, 3 and 4 are selected:
Affected IM addons: "PTC Integrity Modeler Integration for IBM Rational DOORS":
the Doors synchronizer musst be updated so the new multiselct enumeratoins can be sychronized with doors.
1 Comment
Status changed to: Under Consideration
hi,
We have this requirement in our backlog with the ID ART13-7489546 and are considering for a future release.
regards,
Patrick
