Missing error message when opening 8.3 model with 8.2 client
When upgrading the Modeler to server version 8.3 you will be noticed by the client 8.3 to upgrade your existing model in the Enabler DB.
If then someone access the same model with a client in lower version (e.g. 8.2), you will again be asked to upgrade your existing model. But in this case it is a downgrade.
This might be a dangerous situation in a productive environment.
I suggest to not allow clients with lower version to access on higher server version. At least an error message or a warning should be displayed.
Best regards,
Daniel
CAE Software & Systems Engineering
Schaeffler Technologies AG & Co. KG
