Hello, would it be possible to change in Integrity that the pop ups are not focusing control each time?
"Like some users made several mistakes due to this functionality. For example: started resynchronization on the project - it took time. And in the meanwhile was writing some code, then pop up came up and pressed not the correct button in Integrity pop up window."
