Provide the ability to base a QBR off a multi-value IBPL or other multivalue correlation field
From article CS83678:
- Correlate query-backed relationship (QBR) fields from multi-valued item-backed pick list (IBPL) fields
- Multi-valued IBPL fields do not appear in Source Field or Target Field lists on Edit Field dialog for a QBR field
In our use case:
We would like to assign single requirements to releases, but have the need that a single requirement can be implemented in several releases. Therefore it is currently not possible to display on the release all assigned requirements.
