Remove old Enabler in ModelExplorer
0 Kudos
The Integrity Modeler 9 shows old Enabler directory from deinstalled version 8.5. But it doesn't work anymore. There should be a way inside the Integrity Modeler to remove Enabler databases from Integrity Modeler 9 which works with SQL databases.
1 Comment
Level 6
The topic above is not only valid for old Enabler databases. There should be a "remove" option in general.
Additionally invalid entries are also simply created if a new server is added with the default name, for whatever reason.
And last but not least there should be an option to show local databases per default (just like for the old enabler database). It takes unnecessary effort to explain to every user how to add the server instance itself, especially if the server and sql instance is transparent for the user otherwise.
