Sandbox creation with configuration path custom command in the GUI
0 Kudos
as configuration path works better within Integrity and sandboxes can be created with configuration path, but only through command line... =(because the GUI creates the sandboxes with flat path syntax).
Did anyone come up maybe with a custom command of creating sandbox with configuration path of the project?
This would help a lot for our regular Integrity users who prefers to work within the GUI.
Thanks beforehand, bye, Péter
5 Comments
Level 8
I have written a line, but I'm not sure, if this will create a sandbox with Config path or flat path, using the GUI option too?
@ECHO Off
si createsandbox --project=%MKSSI_SUBPROJECT1_CONFIG_PATH% --gui
Obviously the users should define, where to create the sandbox and other parameters (like it should be recursive or not), etc...
Level 8
Level 11
You can paste the configuration path into the Project Name field when creating the sandbox in the GUI. Also, the command you have above will use the configuration path. It's filled in after giving the sandbox location and clicking Next.
Level 7
Level 7
@pbartha Did Ann's suggestion work for you ?
