The name of a tab that shows dashboard item query result should be customizable.
0 Kudos
Issue:
In client administration, when you click a dashboard item, you are able to select a custom query to set the filter condition. However, once you set the query condition and close the "Query: Dashboard item-XXX" window and reopen it by clicking the same dashboard item, the query name changes to "Query: Dashboard item-XXX", which is not the name we desire.As you know, the finally set query name "Query: Dashboard item-XXX" matches with the tab name of the query result in Integrity Client. We want the query result tab name to match with the originally set custom query name.
Request:
Our requirement is to have PTC provide a way to set the query result tab name match the originally selected custom query name. However, for broader use, the name of the query result tab should be customizable without any constraint.
