fault-tolerant handling for user local config files
To better support Integrity Server maintenance use cases, like
- rename a given field
- remove a given field
Possible Solution:
- replace database field names with field IDs in user local config files
This reduces the possibility of a "naming missmatch" when it come to e.g. "traverse fields" Settings in the relationship view.
- fault-tolerant behaviour
Instead of blocking the user with a error message, that the intent view cannot be show, (and that offers no work around), the client should
1. indicate those cases with a warning dialog
2. remove the not matching or missing fields and proceed
