offer recently used items in "add relationship" dialog as default
Currently if you want to add a relationship, you either have to enter the Id directly or select the Item from a query or "finder".
A typical use case in our company is that the item to be linked is one of the 10 most recently viewed items.
So a "fake query" that simply lists the 10 most recently opened Items should by available (as default) in the add relationship dialog to better support our users.
