use walk, walkdoc or walkdocordered functionality in the query builder
this is a refernce to acrticle CS88090
It is possible to add the walkDocOrdered function to a query via command line:
  • im createquery --querydefinition="(walkdocordered[document id])" --name="query name"
This should be supported in the query builder gui as well
It would be perfect if the document id must not be static, but could be defined by a "sub-query" as well.
4 Comments
Level 8
The reverse operation would be useful as well. Finding the documents that a queried set of contents belong to.
Level 11
By "reverse operation" you wish to see not only the containing Document ID , but all Documents that might use this one as include/inserted, RIGHT?
I like that but technically it would still be a "walk" operation, only using different Relationship fields (Contained By & Referenced By).
So in IMHO you use case would be covered implicitly.
Regard Matthias
Level 11
Level 8
