Is it possible to do a setting which automatically moves a comment or requirement below headings?
Target is to have a document structure similar to a word document. Level / section 1 only headings, section 2 for requirements and comments.
Thank you
Markus
If the hierarchy is based on heading style (H1, H2,..) then it will be more flexible and pleasant to look. By this way, the entire document will be structured, with sections -> sub sections -> sub sub sections and so on.
Integrity knows the item category only when it is saved. So this sectioning has to be performed during saving an item.
If their is a possibility of this trigger slows down the operation, then a menu shall provide to "Format Sections" of entire document. This is almost similar to doing format of HTML/XML source code 🙂
Sathish
Hi Markus,
This is possible using Triggers but somewhere you need to define under which heading the comment / requirement should move to.
Regards
Neeraj
