I want to change a content level in excel.
Section | Text |
1 | here is text...... |
2 | here is text.... |
3 | here is text.... |
Section | Text |
1.1 | here is text.... |
So I'm finding many blogging, it could do at MKS solution (maybe in 2008) (reference : https://change.unigroupinc.com/documentation/pdf/MicrosoftExcelIntegrationGuide.pdf , 23page)
But it doesn't work.
this is code that I try in excel integration.
<field external="Relationship" internal="Contained By" field-type="relationship" direction="both" reldirection="backward"/>
and this is error message in excel integration.
"Could not save modified item 3788: MKS124080: Cannot modify standard field: Contained By"
Hi, already replayed in the "old" forum.
Therefore here only for protocol purposes:
a) please ask support if this feature is supported in the Integrity LM version you use
b) I have developed an Excel Loader which does exactly this, but this loader is a loader only, not an editor (even if it may work for this purpose too). If you are interested I am glad to share this custom solution with you.
Volker
