Integrity Modeler vendor daemon
isodius
7-Bedrock
I've just got the Integrity Modeler license for my company. Problem is I don't know where to get the vendor daemon to install in our FlexLM server. The vendor daemon is ARTSANSW.
Any idea where I can get it?
Thanks.
1 ACCEPTED SOLUTION
Hi Lyn,
Thanks for your help. For the record, one has to choose the "Client only" installation option, and then, one can unselect everything but the "Licensing server".
Once installed, one can copy/paste the artsansw.exe daemon to the already existing Flexnet license server, and restart the service.
Finally, the Integrity Modeler can be uninstalled from this computer.
lhenderson
(To:isodius)
Integrity Modeler has a floating license manager component that can be selected for installation when you install Modeler.   You can install just this piece if you have a license server that isn't going to be used for any of the other Modeler components.   If you don't have the installation media, you can download it from the PTC e-support portal at http://support.ptc.com.   You will need to register and login to your account on the e-support portal to reach the download center.
If your Modeler licenses are on maintenance, and you need further details or run into problems with this, you can log a technical support case at =>
https://support.ptc.com/appserver/cs/case/case_logger.jsp
You will need to supply the credentials for your account the e-support portal in order to reach this link.
Lyn
Hi Lyn,
