Add the ability to disable the creation of history records for fields.
In our solution, there are many "read only" fields that are populated by trigger/scripts. These are to copy data that cannot be referenced in an FVA, or building summary tables that cannot be done with a QBR, or calculating internal metrics, or calculating sub-states of the State field, etc. The amount of data, and size of the text fields, that is injected into the history of an item is enormous and renders the History tab essentially unusable to our users.
Our request is that this is implemented in a way that does not block the existing use, or change the default behavior of the existing fields. By having a property on a field that is "Disable History" that is false/unspecified by default, this change would not affect any of the current customers. Disabling the history of a field has to be performed specifically.
If this field is toggle (turned on, then turned off, and then turned on again), we do not care what happens to the history. In other words, when disabling the history, there is no need to update the existing history one way or another. This capability is simply a mechanism to stop, or start, the history. If a constraint is required that requires the history to remain disabled forever, once disable, that is acceptable.
This is in the list of top 5 complaints/requests from the user-community of our organization.
4 Comments
Amethyst
I totally agree with this. If you have many triggers (or other means) that populate fields automatically simply for usability purposes, then the history becomes noise. I need a way to make it useful again and the ability to eliminate the history of unimportant fields would be great.
Regular Member
Hi Sean,
I am moving this idea to Future Consideration.
We will evaluate the feasibility of supporting this in future release when we target changes in this area.
Peridot
Regular Member
In general a good idea but I would prefer to have a filter dialog to configure which fields shall be listed in the history tab instead of configure hard coded to exclude a field from it.
A similar concept shall be offered as already available by view option "Show computed fields in history".
Also important in that context to offer a search function within the item history tab!
