Any way to install i11.1 on MS Window Server 2016 standard edition
acheong
I encounter the following issue
"Flexeraayd$aaa: Windows DLL failed to load
 at Flexeraayd.af(Unknown Source)
 at Flexeraayd.aa(Unknown Source)
 at com.zerog.ia.installer.LifeCycleManager.init(Unknown Source)
 at com.zerog.ia.installer.LifeCycleManager.executeApplication(Unknown Source)
 at com.zerog.ia.installer.Main.main(Unknown Source)
 at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
 at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
 at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
 at java.lang.reflect.Method.invoke(Method.java:497)
 at com.zerog.lax.LAX.launch(Unknown Source)
 at com.zerog.lax.LAX.main(Unknown Source)"
during server installation using i11.1 on Window Server 2016 standard.
Do let me know if anyone can overcome this problem.
3 REPLIES 3
Hi acheong,
Assuming you are talking about Integrity 11.1, it's not supported on Windows Server 2016.  The newer Integrity 12.x releases do support Windows Server 2016.
https://www.ptc.com/support/-/media/82E29D7257A64A38991AEEDF15C8F469.pdf?sc_lang=en
acheong
(To:MichaelChatel)
Thankyou
Micheal.
I will let my management know about this.
acheong
(To:MichaelChatel)
Hi Micheal,
Thanks. Yes ..I get the answer.
Any work around for i11.1 on MS Window Server 2016? Anyway , I think the chance is slim.
