Colon in annotation
Highlighted
Regular Member
Colon in annotation
I am using the API to upload test results. If I have a colon in the test result, then it doesn't upload properly. If I wrap the annotation in either quotations or apostrophes then it'll upload but it'll include those in the annotation. Is there a way around this? I am using Integrity 10.5.
Tags (2)
2 REPLIES 2
Re: Colon in annotation
Hi Nolin,
This seems odd.  Have you tried escaping the colon with a backslash?
Are you using the Java or C API?
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
I am using the C API. I'm not sure what was happening but it doesn't seem to be an issue right now so something else must have been up. I'll have to investigate more. Thanks for the help.
