Hi! We are using the SE Solution, where the category for the type requirement is constrained in the following way:
Constrained Method: Field Relationsship
Source Field: Referenced Item Type
Source Values: Shared Requirement
Constrained Field: Category
Allowed Values: Heading, ...
Can someone explain me why "Referenced Item Type = Shared Requirement" is used here? Why not just "Type = Requirement"? Would that make a difference?
Timo
Hi Timo,
The purpose of the constraint is to restrict the category value based on the type of content the node (requirement) is pointing to (the shared item). The shared item could for example be a Document or a Shared Requirement and usually the constraint you identified below is always paired with a similar document version of the constraint.
Source Values: Requirement Document
Allowed Values: Document
So to answer your question: A node is always going to be the same type, but the type of the shared item can vary.
Hope that helps!
-Andrew
Hi Andrew, I do not understand it yet. The constraint is defined on the type "Requirement". How can the shared item vary? It is always the "Shared Requirement"?
What is the difference to:
1. Basic Constraint; Constrained Field = Category; Allowed Value = Heading, ...
2. Field Relationship; Source Field Type = Requirement; Constrained Field = Category; Allowed Value = Heading, ...
Won't these two constraints work as well?
Regards, Timo
