Dynamic field display size
This is a product idea conversion of case 228058 and RFC 295575 from January of 2016.
Fields should have the ability to dynamically scale to fit their content; this request is for edit views. Text fields may contain a sentence or they may contain paragraphs. IBPLs/picklists and relationships may have 1 selection or they may have 100. Automatic resizing would benefit both authors and consumers.
Ideas:
  • Optional Dynamic Scaling
  • Minimum number of rows to display
  • Maximum number of rows to display
The following text was copied from case 159115:
Allow a field to grow to take up available visible space in Integrity LM
  • Allow the relationship field entry to be expanded
  • Expand relationship field entry
  • Allow customization of a field's real estate
  • Allow a field size to be customized in order to take advantage of available space
7 Comments
Amethyst
Great idea, would address one of my biggest pains with Rich Text fields especially.
Aquamarine
Link to case solution:  CS228058.
Aquamarine
There is also a very similar Case https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS86385&source=Case%20Viewer (open since 2012!), which leads into RfC 121984.
Newbie
May also overlap with the thread about the UI presentation templates and editor, where a field definition may indicate to use whatever space is available, and then the presentation template defines that space (in a better manner than it does today).
I can see this being useful on many field types.
Aquamarine
"PTC Inc is working on a plan to revamp the UI & this idea is likely to find a place in the new UI that we want to build. Please watch-out for an announcement related to this in the coming weeks.
Aquamarine
Community Manager
