Group membership reporting
When reporting group membership using any of the CLI calls or api, identify which groups the user is a direct member of and which they are a member of due to a nested group.
1 Comment
Tag
Value
Status:
Reviewed by PTC Community Member
Main Category:
Integrity Lifecycle Manager Administration
Sub Category:
Users and Group Management
Related Working Group:
Standard Functionality validated:
API, CLI
Standard Functionality available in Release 11.2:
No
Workaround exists:
Yes
Workaround Description:
A simple SQL query will return the data you are looking for.
see below
Workaround match:
100%
Other knows solutions:
Pull out all group details using CLI or API, and analyse programmatically the direct assigned groups. But this approach is quite complex, and you would always read data which you don't need to answer this question.
Related other Ideas:
none
Related Questions:
none
Related Tips:
Administration Configuration Reports
Next review Milestone:
01/11/2018
Use the following SQL Command to list the direct group assignments (Oracle version):
select PrincipalName||';'||GroupName from MKSDomainGroupMembers where IsGroup=0 and PrincipalName='<username>';
Side effects:
When you execute this SQL using "im diag --runsql", this call will be tracked in the server.log
