Highlighting use of types in a diagram
When we have a diagram there can be many places where we use the same type. We would like all places where a specific type is used to be highlighted. See the attached example where we have used the Test Signal1 several places on the diagram. In the output window you can see that are different things that use the signal as a type.
even
1 Comment
Aquamarine
Status changed to: Under Consideration
Thanks for the idea, this would be a useful feature to have. I've added to our backlog with the ID: ART19-7405459 and we will consider for a future release.
regards,
Patrick
