How do I access the Query Results in a Trigger Javascript and Manipulate the Results. I am trying to Delete the Decomposes To traces from the Document Node Items when the Document workflow reaches to Retired State.
SOLVED
Newbie
@I need to access the Query results record Objects in my Javascript Trigger file from the attached Scheduled Trigger Query. What Java/Javascript Beans are used to access the Query Results. attached Trigger script works fine now.
Message was edited by: Laxman Dobbala
Re: How do I access the Query Results in a Trigger Javascript and Manipulate the Results. I am trying to Delete the Decomposes To traces from the Document Node Items when the Document workflow reaches to Retired State.
I just posted the working script by myself. help Yourself.
