How to delete/brake the "Branch Information" between documents?
fhuber
Is it possible to delete (or brake) the branch Information between documents?
For example I have document A and create a branch document B.
Now I have the Information in document B, that document A is the root document.
How can I delete the root document Information in document B?
I've tried to change the reuse property but that's not exactly what I am looking for.
Sometimes it is a bit confusing if I run a document report and see the branch or the root document.
Thank you very much for your help!
Florian
HI_9415398
(To:fhuber)
to break the branch, you will need to toggle the item from Shared to Reuse and edit one of the "Significant Edit Fields" of that item type
amund
11-Garnet
(To:fhuber)
Take a look at the following: (Branching Documents (ptc.com))
This may be the answer (which you did not want...).
