How to deploy custom WAR files in Integrity 12.2?
Regular Member
Deploying wars in IntegrityServerInstallFolder/server/mks/deploy doesnt work.
we restarted service as well
but no luck.
we tested on local Tomcat, it works fine.
do we have any details on this?
3 REPLIES 3
Re: How to deploy custom WAR files in Integrity 12.2?
Hi @cummins2019 ,
Just try to put them in Client Directory (<ClientInstallDirectory)>/check.war) and then try to launch them with URL something like this (http://<hostname>:<Installationport>/check.war) , i am not 100% sure but just give a try..
It looks like with the changes done in the Integrity 12 and higher versions, to accommodate architectural changes from JBoss to Tomcat, there is more customization needed.
ex.
https://www.ptc.com/en/support/article?n=CS301619
If it's a war file from prior JBoss/Integrity usage, it would need to be made compatible with Tomcat.
ex. Modifying the existing deployment descriptor "web.xml" and also creating a web service deployment descriptor "sun-jaxws.xml" in the war file.
Seems like the general steps for a Tomcat .war file, as I understsand it, would be:
Copy the custom war file to following location in server install directory : server/mks/deploy/
2. Create a xml file in following location in server install directory : server/conf/Catalina/localhost/
        The name of the xml file should be same as the context in the URL. Generally format of URL is like, http://<hostname>:<port>/<context>;
        Example: If the URL is http://localhost:7001/demo/sample then name of xml file should be demo#sample.xml. Note that / in URL's context is to be replaced by # in name.
        Then add below content to xml file:
        <Context docBase="${catalina.base}/mks/deploy/<name of custom war file>.war" crossContext="true" cookies="false">
        <Manager pathname=""/>
        <JarScanner scanClassPath="false" scanAllFiles="false" scanAllDirectories="false">
                <JarScanFilter tldSkip="*.*"/>
        </JarScanner>
                  </Context>
In the above example content replace <name of custom war file>.war with the name of custom war file.
Consulting with PTC's services/solutions folks, seems like it might be a good avenue.
Highlighted
still facing the error:
2019-09-11 07:56:05,023 ERROR [mksis.IntegrityServer] * * * * ERROR * * * * (0): javax.servlet.ServletException -- javax.servlet.ServletException: Servlet.init() for servlet [Add_ON_Helper] threw exception
Caused by: org.glassfish.jersey.server.internal.scanning.ResourceFinderException: The URI scheme war of the URI war:file:/apps/cummins/Integrity/IntegrityServer10/server/mks/deploy/AddOnHelper.war*/WEB-INF/classes/com/main/ is not supported. Package scanning deployment is not supported for such URIs.
Try using a different deployment mechanism such as explicitly declaring root resource and provider classes using an extension of javax.ws.rs.core.Application
