Hello and good day,
we are using Integrity 10.8 and need to change the Test Session/Case workflow so that only specific Test Cases (state = Active) are added or their verdicts editable within the Test Result Editor.
Currently every Test Case of a Test Suite is added to a Test Session and their verdicts are editable, no matter what status the Test Case currently is in.
Would someone please explain how we can achieve this requirement or maybe its not possible?
Thank you very much!
