Hi All,
How to set Read only on "TEST RESULT" fields.
Integrity: 10
Thanks in Advance
-Shankar
Hello Shankar,
I've asked around, and received a number of qualifying questions from senior support engineers. In summary, though, they suggested that your best bet in this case is to contact customer service. Alternatively, if you could elaborate:
Kael
Hi Kael,
Thanks for your response.
1. I would like to set "Test Result" fields in general read only.(It has to edit only through trigger).
2. I has to set globally.
-Shanakr
Hello Shankar,
Unfortunately, Test Result Fields do not directly support the concept of Editability. You could impose editability limits through the use of trigger scripts.
If this is an important feature to you, please contact Integrity Support to have an SPR created. (An SPR, or Software Performance Report, is equivalent to what MKS called an RFC, or Request for Change).
Kael
