How to use trigger command "setRelationshipFieldValue"
tpatel
11-Garnet
I am currently creating a javascript trigger for Integrity 11.2. I am trying to link a document into a relationship field using the command "setRelationshipFieldValue". To test, I've been using the following code
                                "                                          var a1 =[];
        a1[0] = 50807;
                                      delta.setRelationshipFieldValue("Related Validation Request Document",a1[0]);
When I run this, I get the error "cant find method". What am I doing wrong/What can I do to fix this issue.
Thanks.
1 ACCEPTED SOLUTION
4 REPLIES 4
awalsh
(To:tpatel)
I think the issue is that you are giving a single integer value, and the method is expecting an array of integers.
setRelationshipFieldValue (java.lang.String fieldName, int[] value)
 Set a relationship field to an array of integers.
Does it work if you use:
delta.setRelationshipFieldValue("Related Validation Request Document",a1);
tpatel
11-Garnet
(To:awalsh)
When I use that method, I receive another error prompt saying that the argument types are ambiguous.
awalsh
(To:tpatel)
tpatel
11-Garnet
(To:awalsh)
This is exactly what I was looking for. I got it working based on this article. Thank you.
