Im getting JavaScript Error in a IM trigger
aharms
2-Guest
I am trying to get the User Object from imUserBean, but I think it cannot be created: JavaScript Error: Internal Error: undefined: Cannot convert null to an object
function main()
    if(delta.isNewlyPosted() && delta.getNewFieldValue("Severity") == null){
        abort(user.getFullName());
var delta = bsf.lookupBean("imIssueDeltaBean");
var eb = bsf.lookupBean("siEnvironmentBean");
var user = bsf.lookupBean("imUserBean");
main();
So I am trying to create the object with bsf.lookupBean and then abort the action with the full name of the user who caused this action.
Instead I get the error in the line (bold).
Thanks in advance
Alexander
1 ACCEPTED SOLUTION
mrump
(To:aharms)
There is a difference between user beans from the Integrity Manager (Workflow & Documents) and the Domain Users.
Unfortunately both use a Bean called .....ScriptUserBean
  • mks.si.brain.triggers.beans.ScriptUserBean
  • mks.ci.server.engine.LocalTriggerManager.ScriptUserBean
I'm not sure with one is returned by
Nevertheless, every time I tried to solve a task like your's in the past I ended up using the following template:
//get the Server bean
var sb = bsf.lookupBean("imServerBean");
// get the bean representing the current item
// fetch the user name from the current item's bean e.g.
var currentUserName = delta.getCurrentUser();
// retrieve the matching user bean from the server
var userbean = sb.getUserBean(currentUserName);
// analyze the user bean
if( userbean.isMember("a Group") == true ){
  // do something
5 REPLIES 5
mrump
(To:aharms)
HI Alex,
i assume your user is null, as
ives you an undefined user bean.
I'd choose someting like this:
var user = delta.getCurrentUser();
or
var user = delta.getCreatedUser();
or
var user = delta.getModifiedUser();
given your use case, they should all return the same user.
HTH Matthias
aharms
2-Guest
(To:mrump)
thank you for your reply.
Iis not described in my question, but I need furthermore the group of the user, not only his name.
I want to try something like this:
if(user.isMember("Some_group")){
     abort("foo");
I dont understand why this bean is empty or null. Because I use a Domain User who is imported into Workflows&Documents. It must have bean for IM user...
Any other idea how to get the user and its groups or membership of a specific group?
Thank you
mrump
(To:aharms)
  // do something
KaelLizak
(To:mrump)
Hello Matthias Rump‌,
If you look at the JavaDoc followed from the Event Trigger Java Documenation off of most server's home pages, the method getExposedName() of a given class will tell you the name of the bean used for bsf.lookupBean(String foo).  In this case, it's mks.ci.server.engine.LocalTriggerManager.ScriptUserBean.
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
aharms
2-Guest
(To:mrump)
That is exactly what I am looking for.
Thank you very much.
