Import Interface for Decision Sets
The decision set editor currently provides an interface to export decision sets in an XML format. A corresponding import interface is not available. It would be desirable to have such an interface that can read decision sets edited by external tools.
2 Comments
Aquamarine
hi Ulrich,
The Modeler API (automation interface) can be used to read/write Variation Points and Variants. There are also APIs for decision sets which are restricted access so you would need to discuss with your PTC account team.
If would help if you can provide more information about the external tools you would like to use for editing, and the details of how the process would work.
regards,
Patrick
Aquamarine
Status changed to: No Plans to Implement
