Integrity LM: Administration Configuration Reports
Intention
This document is intended to describe the current status of Integrity LM configuration reports and to collect related discussions and ideas.
Configuration Reports for W&D
  1. Integrity Docs
    • Custom developed offline solution creating static html pages about types and triggers for review and sharing
    • Is provided as a JAR file to be executed on client
  2. One alternative is "Type Fields in Excel"
    • Custom developed offline solution creating Excel Files instead of html files with similar information
    • Especially helpful when you are in a workshop and like to track requested changes directly in Excel for later implementation
  3. IMConfig
    • Custom developed Online solution for Admin reporting. For Type-Fields, the same java code is used here like in solution #2.
    • And, it offers many more reporting, not only "Type-Fields-Workflows". For example, it offers also reporting for User-Group-Dynamic-Group details.
    • Is provided as a single WAR file to be copied to the server
  4. Administration Reports
    • Custom developed Word Export showing Administration Configuration Details for Types, States, Fields etc.
  5. CLI
    • You can use the CLI to create config lists in CSV or XML format, and upload the same into any custom reporting tool.
    • I am using #3 instead, where possible.
  6. Relationship and Trace Listing
    • Custom Developed Excel List for all admin Relationships  and Traces. Created for Documentation and Validation purposes.
  7.  Trigger Overview
  • This report lists all Triggers with the name, and they are ordered by the type names on which the trigger fires.
  • Each box represents a trigger. Additional flags highlighting the type, the pre or post mode, if a script is linked etc.
Configuration Reports for Config Mgmt:
  1. for ACLs:
    • Standard Client Form providing ACL details in regards to given ACLs for users/groups and projects, subprojects
  2. In General
Next Steps
  • If you are aware of any other solution that I should list above, please post it here as comment.
  • If you are aware of any other related Idea or Discussion that I should reference, please post it also.
Related Discussions:
For W&D:
PTC Integrity Configuration Report
Re: Is there a possibility to give out all definition done in ILM "Workflow and Documents"
how to compare two Integrity configurations
Volker
Re: Integrity LM: Administration Configuration Reports
7. Trigger Overview  (added in Nov 2017)
TriggerDoc.PNGTrigger Doc (created with Java)
Where are these utilities located?
Hi Paul,
Thanks for asking. If you are a PTC employee you can get them from our internal reusable database. If you are an external (non PTC) employee, then drop me an email or a personal message with your email adress and I will contact you from where you can get them.
Thank you
How to generate this report?
Is there any way to kill a trigger and initiate it again? I am asking just in case there was a blockage and we killed the trigger , so how to trigger the trigger again??
about "How to generate this report?":
Please send me your contact and company details in a personal message.
about: "Is there any way to kill a trigger ....".
Please post this question into the Questions forum section, not under Tips.
Thank you.
