Integrity Modeler Doors synchronization: using doors module id's instead of absolute path and module names
Proposal to use the doors module id's instead of absolute path and module names as reference for mappings. Because currently all mappings need to be updated if a doorsmodule is renamed or moved. For a 100+ mappings this means a high expense which could easily be avoided.
2 Comments
Aquamarine
Hi Arne,
Thank for the product idea. I spoke with R+D and we agree this is a good idea so I've added a requirement to our backlog with the ID "ART16-22177986".
It's set as a medium priority which means there are no immediate plans to implement.
You can raise a case with Support if this is a significant issue, and we will review and re-assess the priority.
Patrick
Aquamarine
Status changed to: Under Consideration
