Integrity Modeler interface to Enterprise Architect
The proposal is to create a performant interface to Enterprise Architect (EA). It shall provide high quality import / export options to Integrity Modeler (IM) for model elements AND diagrams. In a further approach also synchronization shall be possible.
Such an interface would be needed i. e. for development projects in which the development partner uses EA, but the own company needs to have the results in PTC IM for further detailing (not only documentation).
Possible scenarios for the exchange with suppliers and development partners:
  1. single transfer of EA – Models to IM
  2. ongoing modification / synchronization from EA to IM
The actual universal interface XMI is far not sufficient because no elements can be imported and no diagrams can be transferred. Sync. is also not possible.
Furhter information on EA:
http://www.sparxsystems.de/start/startseite/
2 Comments
Aquamarine
Hello Arne,
Thanks for submitting the idea. This is something we've discussed in Product Mgmt, but our current roadmap does not include a direct integration with EA.
We're planning to provide OSLC capabilities for our next release of Modeler (subject to change) which would potentially provide a way to integrate with EA, but it may not fit the full model import/export and re-synch use cases that well.
Patrick
Update: we have this requirement in our database with the ID ART11-7118489
Aquamarine
Status changed to: Under Consideration
