Integrity Modeler, remove character limit for operation identifier (type: signature)
0 Kudos
At the moment the identifier for operations is limited by 100 characters.
Entering a signature for an operation with more than 100 characters results in an error message. There is no such limitation known in coding guidelines (i.e. C-standadard). On the contrary, a theoretically unlimited character number is explicitly defined for the identifier.
Suggestion: remove or increase the limit for the identifier of operations  (type: signature).
4 Comments
Aquamarine
Status changed to: Under Consideration
hi,
Thanks for the idea.
I've added this requirement to our database with the ID ART18-18185978 and we will consider for a future release.
regards,
Patrick
Aquamarine
R+D have commented as follows:
The name of the Operation and the name of Parameters are each limited to 100 characters. This does not limit the total size of the signature.
Is the request to increase the limit on size of the Name of an Operation?
thanks,
Patrick
Visitor
Yes. As (a part) of the signature is written to the operation's name the character limit of the names schould be increased. By the way, it would be nice if the character limit of the element names in general would be increased (packages, blocks and pins / ports, requirements).
Arne
Aquamarine
thanks, I've updated our requirement.
Patrick
