Integrity Source: compare independent files directly from Integrity without creatign a sandbo
0 Kudos
we often have a compare problem if e.g. files are remaned or dropped or moved to another library or located inside another project.
There is no solution inside MKS/PTC to compare e.g. different files inside a Change Package (dropped / added/ moved/ renamed)
or files with the same name located inside different projects using the project view.
Current situation:
only file versions located inside the same source project can be compared
Requested feature: files from different projects with the same name can be compared and files belonging to the same project but have different names can be compared.
