Is there a way to maintain the order in which the items were inserted into a relationship field in a chronological order?
rraj-2
The Order column is not helping me here.
1 REPLY 1
KaelLizak
(To:rraj-2)
Hello Ritu Raj‌,
In Integrity Lifecycle Manager 10.6 this is already the case.  If you add a relationship in the GUI, by default it will add that relationship to the end of the existing relationship set.  If you add from the command line using im editissue --addfieldvalues=<RelationshipName>=<ItemIDToRelate> <ThisItemID> it again appends the related item to the end of the list of items in the relationship list.
Does that help, or do you need additional information?
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
